If you are starting from ground zero with nothing done yet, go with Caltracs. We have been looking into rear suspension for a while now and took out the ladder bar that was very crude set up built by a previous racer but still ran in the 8s with it. Fixed the floors on the Cuda and putting in the complete Caltrac Systems with Mono Leafs and back slider. You get to set you own ride height and various over things to make this work and fit better that we needed because the front segment of the spring need to be a longer that the 20 inches of a front super stock spring. Talked to Caltrac and they were great help. We run 20" (A-body) front segment because that's what my '63 came with. No issues at all.
'63 Dodge 330 11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs. 10.01 @ 133mph with a 250 shot of nitrous an a splash of race gas. 1.36 60 ft. 3,700 lbs.
