Originally Posted by DrCharles
I'm running the Ford Contour dual fans with an Autocoolguy PWM controller. 3-row 26" aluminum radiator. It fits the radiator like it was made for it. Brackets were simple. A little trimming of the plastic in the WP pulley area is needed - there is not a lot of room there! My big-cam 451 can idle all day at 182 degrees up
I too use that fan setup. I had to trim the center for my Meizere pump too in case some may think its only a stock pulley issue. I have a different brand controller though and I'm likely moving the fan control duties to the Holley Stealth Sniper system since it has the capability and will rid me of some extra wiring. Mine is also a 451" powered Demon
eBay-cdwmotorsports
