At minimum, especially if it’s a street/strip car, run a shroud with fan, or even a small shroud with electric SPAL fan. You could even try pusher or puller arrangement with an electric SPAL fan if you have the room. Here’s my setup.
"If you can still hear your fears - shift a gear."
