( Last post for a while; I've overloaded the forum in the last couple of days )
Has the current supply chain chaos given you a sense of urgency about buying parts, tires, etc., "now" if you come across something that you think you'll need, rather than risk not being able to find them when you know for sure you need (or can better afford) them?
I already have hoarding tendencies, so this situation is just making it worse.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
