I have been trying to do everything ahead of schedule. I knew slicks were hard to get so I bought a set for this year. I also bought two sets of front tires that will be going on early this season. I lost my local alcohol connection so instead of driving 7 miles each way its own 40 miles so I’ll by two barrels instead of one as the price is going up for sure. It already went up 45.00 a barrel from my last purchase. The 408 in my car is fresh but I already received a Molnar 4 inch crank for my 422. Rods from Molnar are on backorder. I will be mic’ing the crank for bearing size so I can order them ASAP and since Cometic gaskets take longer than usual I will get an order in for those. If you wait till you need things and wait you will miss some races. I even filled my dodge diesel up today so I have it full for test n tunes in April
