Originally Posted by Jeremiah
If you are a Milwaukee M18 type of fellow PM me. We sell a base and everything you need for an automatic bottle heater. The transducer we use holds pressure within 25-50 psi.
For the controller I suggest the NOS mini progressive because it has a window switch, delay, and can monitor you bottle pressure through the handheld for about $200 extra.
The NOS mini progressive is just over $200.
I should probably get a controller at some point rather than just hitting all of it off the line. grin
'63 Dodge 330
11.19 @ 121 mph
Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
10.01 @ 133mph with a 250 shot of nitrous an a splash of race gas. 1.36 60 ft. 3,700 lbs.
