If you are a Milwaukee M18 type of fellow PM me. We sell a base and everything you need for an automatic bottle heater. The transducer we use holds pressure within 25-50 psi.
For the controller I suggest the NOS mini progressive because it has a window switch, delay, and can monitor you bottle pressure through the handheld for about $200 extra.
The NOS mini progressive is just over $200.
