Originally Posted by fbs63
Just an FYI on this subject. Strange has Mopar bolt pattern housing ends that take a 3.150 bearing so you can use 40 spline axles and still use existing brakes.
Thx. I didn’t lnow that. But, I am starting from scratch with everything and will prob get the Strange pro race setup along with the axles.
1.50 60Ft. , 10.75@ 127MPH Hauling 3900 LBS.
