This has been the coldest January since I moved to North Carolina. And my shop does not have heat, so the header build has limited afternoon work hours this month...
Slow, but making progress. I have only built one set of headers before, in the winter of 2007-2008. But after the first couple fit ups and tack welds, the third (cylinder 5) went much faster to the tack weld stage.
Nice looking shop. Why no heat? Not usually required in your parts? I went with radiant floor heat when I built my shop and I love it. I can work out there year around and it is super comfortable. When it gets below freezing I have to use a space heater to help out but otherwise the floor heat keeps up.
