Never ran a cast 440 crank in a mild race engine, as there were always a lot of stock forgings around. I have built several big block Chevy's with cast cranks at around 500HP level and no problems. I would think a cast crank Mopar at the same level of power would work just fine especially if you use lighter rods and pistons.
