I’m considering a set of second wheels due to the discovery of my factory road wheels being bent. I had to get new tires to even drive the car home since those were ancient. I had them mounted and all four are bent significantly. I love the old redlines, so thinking I’d run them locally and have a bigger set for long drives.
On the hub issue, seems the year one 17s should have the specs we need. Not sure I like those rims for some reason. Holley has a set of 15s or 16s that are road wheel look that I considering.
Tire rack has some 16s from American racing that I like, but want a black center instead of gray. Will probably call them and see if they can get them since AR lists those. Using tirerack would save some hassles with the mount and balance. They list several rims as being for plus 1-2 for our cars.
