"Old school" motorcycle front suspension regularly used "fork oil" with advertised weights of 20 - 30. When the more sophisticated cartridge-style forks using tunable stacked shims came into play, those units were typically spec'd to use 5 - 7.5 suspension fluid. One of the reasons was because the heavier weight lubes broke down so much faster when exposed to on-track demands. I just found this list of various manufacturers' suspension fluid specs to use for reference. Maybe it'll help. https://transmoto.com.au/comparative-oil-weights-table/
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
