Swapping tires at the track means I can't take a passenger with me. One wheel gets stuffed behind the rollbar and the other gets the passenger seat... it's a bit of a PITA, but I did it regularly before switching to the MT ET Street Radial. FWIW, those actually weren't horrible in the rain when they still had some tread depth -- much better than the BFG Drag Radials I tried before them -- but you did need to keep your brain engaged on wet roads.
I've got a new set of the original ET Street Radials that I bought when they were discontinued, so I do have something to use when the car's rolling under it's own power. They did well as dual-duty tires and still pulled 60s in the mid-to-hgh 1.4s., but now the car is gonna hit the tires even harder. It's their replacements that I'm thinking about now...
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
