Wide or narrow bushing? What is the endplay? Are the reaction shaft support ring grooves square? Or are they tapered ? Steel or aluminum drum?? Cast or Teflon sealing rings? What is the line pressure? What did the high frictions look like? Never had a drum cause a vibration.
Doug
