We don’t mill the flats,we trim the length to fit , when theses are in a stock LS block you essentially turn it in to a 4.46 BS, I milled the sides of the sleeve once for a street build last sleeves in a 6.1 block, had . 100 between the sleeves.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
