So they just leave a .060 water gap between the 2 sleeves when using LS MID sleeves in a G3?
Honestly I don't know, He left for Germany last night and will be there till mid Jan, I can ask him when he's state side again
I know on the LS applications the Sleeves are milled on the side so they can "siamese" bore, I don't see why he wouldn't do the same with the G3 ,
Yes, the surface that meets an adjacent sleeve is flatted and designed to nest against that sleeve with the flat. When adding .060 to the borespacing there would be a gap between the flats when the LS kit is installed in a Hemi. Just curious how they worked around it. RTV? Weld?
