1974 Roadrunner with 440 & 727. The old torque converter's hub was worn out and the pump seal wouldn't seal and one of the flexplate mount pads was stripped so I ordered a reman replacement.
Replacement arrived and looked just like the old one with balance weights welded on each side of the drain plug.
Installed it and noticed immediately a new vibration off idle. Don't have a tach but you don't have to give it much gas to feel it.
May be happening at idle, but don't really feel anything until the RPMs go up. Under the hood at idle the engine sounds like a precision sewing machine and isn't shaking or moving at all.
The converter works, car drives fine, no odd noises, just vibration. Everything rattles at certain RPMs... steering column, console, etc.
What happened here? I am at a loss for how installing a weighted converter in place of a weighted converter can introduce such a dramatic vibration problem.
Everything is stock... motor stock, original flexplate, etc.
Very frustrating problem... was hoping to solve some problems and ended up with a worse one!
Any thoughts?
