Maybe, I guess I'd try it and see how it felt. The keyway should be strong enough to withstand the load and so should the 3 bolts for a Chevy pattern or 6 bolts for a Mopar pattern. With spark plugs installed it can take over 100 ft-lbs to rotate the engine, maybe more on a igh compression engine.
