Originally Posted by 440Jim
Andy, I like that big nut on the end. Should be suitable for turning the engine with a wrench by hand.
Yes, the spline drive setup from Peterson is strong enough that the engine can be rotated with the large nut. The Chevy style mandrels will break if you try to use the center bolt to rotate the engine.
