Yep, the "old days". ATI damper with Chevy accessory bolt pattern. Not much made crank trigger and pulley wise for Mopar then. Easier to make brackets for the pickup etc, than to reinvent the wheel.
No reason not to do something to use the most common accessories available now either.
If the results don't match the theory, change the theory.
