I was able to find the lifter from the wasted lobe and looked more closely at it. It looks like the scarring is all in one direction- like it never rotated.
I will change to another brand with a lift no more than .500 and clean up my lifter bores. No cam lube on the sides!
So have you pulled the motor down after losing 2 cams?
OR ...at least drop the engine oil pan. THEN put a magnet in there to collect the rest of the "trash".
A bunch of the metal is up in the skirts by now...
