I don’t believe 440 Source has offered the Stealth heads CNC ported in quite some time.
Not that you couldn’t buy the heads and have a porting service do them up.
I had a customer looking at buying some Stealths and called about them the other day.
He was told they didn’t expect to have any for quite a while.
I think many heads(and a lot of other things as well) are going to be bought based on availability.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
