A mid plate is more than an engine mount, if it is properly mounted it stiffens the firewall area of the chassis and adds as a safety net of sorts if there is a catastrophic transmission failure. Not knowing what chassis aids you have ( full cage, roll bar only?? ) a properly sized mid plate can be mounted at the bottom and top to chassis/frame members and significantly reduce twist between the engine mount and forward rear suspension mount . Again more needs to be known about the car to give more in-depth opinion. but my vote if it’s a race car with modified chassis/body components it should at least have a 1/8" mid plate as a trans failure safety mechanism. twocents
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
