I have a question when setting the motor up in a new car connect the transmission to the crossmember After that how high do you set the motor ?? I’ve heard 3° however is that with the rake of the car? Level on the intake? Please keep in mind the crossmember has no motor mounts right now so I cannot put motor mounts in and then put my plate in
