Originally Posted by madscientist
I found one of the cooler lines had split. Right in the seam. So that thing was leaking from that seam for a long time before it blew like a death aneurism...
I had something similar when I bought the '65 Satellite. I was taking it apart for restoration - and I found the trans cooler lines were routed wrong by a prior owner. One of the trans cooler lines was rubbing against a chassis part and was worn razor thin. Must've been that way for years.
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
