Originally Posted by GomangoCuda
bent or warped cover, cheap plastic cover, loose converter bolt, incorrect converter bolt. Correct converter bolts have thin heads and DO NOT use washers of any kind.
Cracked or bent flex plate.
Or the crank thrust bearing is severely worn. shock
The INTERNET, the MISinformation superhighway
