Originally Posted by stumpy
Are the convertor bolts hitting the cover?
hahaThis.
Incorrect, bent or warped cover, cheap plastic cover, loose converter bolt, incorrect converter bolt. Correct converter bolts have thin heads and DO NOT use washers of any kind.
Cracked or bent flex plate.
In theory, there is no difference between theory and practice. In practice, there is.
