If you can get 100 lbs on the seat and 250 to 275 open that should work well,
The whole idea is to reduce the risk of wiping a lobe, so just enough to run 3000 rpm is all you need. I like the above numbers. You can try more, but the more the more risk. Sometimes you get lucky with full pressure, but do you feel lucky, punk? (Clint Eastwood)
