Originally Posted by carnut68
The old 509 cam,Team G intake[junk] 3800 convertor 3.91 in an Abody it ran 11.91 @111. .
Personally, this is not the example I would use to make the case that you can make power with low compression.
I know what you are saying. I didn't build i, but it made power. Mismatched parts and all.
Hmmmm. I would call it a good running car, but not good power. Unless the A body weighed 4200 lbs, or the DA was 10,000 ft, that motor does make good power IMO. Of course the details matter.
