Try stress relieving the LCA bushings @ static ride height,loosen each LCA nut while vehi.is on a drive on lift or the ground,jounce the front of vehi.a couple of times & re torque LCA nuts, some times bushings are tightened when the arms are hanging creating pretension on the bushings,this can really make a vehi.ride like crap.
