So I didn't find any reproduction for that upper trim rail. I did see an eBay auction that listed "Mopar B Body Front Upper Door Panel Chrome Trim Charger Satellite 1966-1970.
Fits 2 Door cars only. Does not fit 1966-67 Charger.” So if I want to believe that, they were the same 1966-1970. The same vendor has the rear seat side panel trim but that is listed as "1968-1970".
For some of the door panels listed, such as the 1965 Satellite, is says "Customer must reuse original metal trim." But it doesn't say that for 1966 Satellite. In the photos it clearly shows that there is a lower trim that should be on the panel. Guess I'm going to have to keep hunting.
Does anyone know if the 1967 and up automatic center console will fit in a 1966? If I understand correctly the 1966 was originally a 2 piece. But will the 1967 physically work? I'm not going for concourse correct. I'd just like to get the car back together and drivable within my lifetime.
Thanks!
