I suspect that before long you will be either cutting the tunnel of your RR or selling that transmission. This is more of a transmission angle problem than pinion angle. I suggest you add TKO swap to your Title so that the experts on this swap will be here shortly.
In theory, there is no difference between theory and practice. In practice, there is.
