Originally Posted by Guitar Jones
Output shaft bushings are the same. That front pump bushing is bronze. I've used them all with no appreciable difference.
I might just leave the front since its brand new and already "worn" into the hub a little...
The output shaft bushing is also brand new but it has a little scuffing, which is normal I know but I also noticed that the notch doesn't line up with the housing. The notches in the new one will match the housing perfectly.
Someones going to tell me it doesn't matter...
