I was just warming the car in the garage checking things and sparks came from the scanner tool part and I opened it up and a resistor had exploded.There may be more wrong with the tool but I am sending it in to be fixed and find out.You guys that have this tool may run into this problem or have had this problem.The resistor may only cost .50cents.
GOTBOOST!New improved with Victor heads.
http://www.enginelabs.com/mopar-big-bloc...t-of-necessity/
