Are you looking for the rubber just for the sliding parts of the window, or the whole gasket? Reason I ask, is I used to have an 84 D350 with a solid glass, and a friend gave me a sliding rear window. I had a glass guy come swap it out, and he reused the same gasket that was around the perimeter opening. Of course, this was about 1990 when the truck wasn't very old.
Are you sure your friends slider was factory and not aftermarket
