I have a 68 Charger disc upgraded mild street strip car was thinking of changing pads out to EBC pads. I'm not a fan of semi metallic and ceramics aren't available. Only other option is organic which has worked well on another vehicle. What color do you suggest?
If this is the company out of Las Vegas then I would highly advise against buying ANYTHING from them! I bought "red stuff" brake pads from them several years ago (once again - if we are talking about the same type of pads) & they disintegrated down to the backing plates in about 4,000 miles - I could not believe it. Worst junk I've ever run for brakes. I contacted them & got nowhere. FYI........
