1st. how much chassis travel do you have ? then you can make the proper choice for springs..... you need to be as soft as you can without using all your [chassis] limit of travel. you can use shock travel indicators to get the info. getting into the corner is -everything-- you will do better to rate your springs by lbs. per inch of compression. find out what you have now and with the shock travel info you can see where to go.
