Ford put out a bulletin this week about being careful to avoid exposing their EVs and hybrids to excessive heat, which is causing concerns about the paint process in the collision repair industry. It will be interesting to see what's done to ensure proper refinishing if shops can't use the bake cycle on their booths at the temps they normally would.
Earning every penny of that moderator paycheck.
DBAP
