I've always found the senders rust from the outside and usually leaks from around the lines is from the solder or other problems.
I guess the other plus of new is you know there will be no problems with the float and with the luck I have I'd skip the new sender and then it's not available anymore when I need it. I've read a ton of problems over the years with aftermarket senders not reading properly or being erratic etc.
