Yep, two flasher units. The easy one to find is always the hazard flasher and it seldom gives you any problems. For some reason, Chrysler thought it would be fun to hide the turn flasher that goes bad. Generally the turn flasher is connected to a connecter that is separate from everything else. Often they are found hanging under the dash by the wires, near the radio & ash tray.
It wasn't until the mid 80s Chrysler decided to put the turn signal flasher on the fuse box along with the hazard flasher unit. Gene
