Something I never really gave much thought because I’ve never had to replace it, but, is the three prong turn signal flasher on my ‘Cuda some sort of unicorn? 😂
I can’t seem to find anything that matches up, just the universal style. If I have to, I’ll make some jumper wires to connect a standard flasher to the original harness, but would rather not.
I switched over to LED bulbs and the LED flasher I received is a two prong. It worked for my hazard flasher but I need one to work for my three prong turn signal flasher 🙃
