With the Duster I am building, I will stay with 10.5" wide rear tire for class purposes. In a thread in a facebook group about rear tire size, this guy explained he has a 10" wide wheel with 5.5" backspacing with a 28"x12" tire on his Duster by using an offset shackel/hanger kit. Even though I already have the UScartool spring relocation kit, if all I need is the offset kit to get the 10.5" tire in there, then that's what I'll do
With all of that said, what's the max offset these kits come in? I see Doc Diff has 1/2" offset but is that the most offset you can get? Mancini only lists B and E body kits as far as I can tell
Where are you guys getting these kits? I don't see them in Summit or Jegs. Maybe I don't know how to find them
