A real true Daytona front wheel opening IS NOT a modified 68, 69 or 70 wheel opening opening molding. Yes the 68 thru 70 molding can be snipped and bent or stretched to fold out to conform to the Daytona profile as shown is CSK's link. The true Daytona molding however is longer than a 68 thru 70 molding by about 1/2 to 3/4 inch and is cut off square unlike the regular molding which has a little extended divot. It actually hangs below the Daytona lower valance by maybe 1/2 inch when installed. Follow down in CSK's links post for Hemi Geno's post at bottom of the page. He explains it also and has photo of the extra length. Real Daytona wheel opening moldings are I would say VERY hard to find in this day and age. Its very easy to spot a car with the correct ones. They will over hang the lower valance and are cut off square. 68 thru 70's can be cut square to replicate the Daytona version but they will then be too short.
