Originally Posted by cl440
You shouldn't need 2 vents and you shouldn't need to relocate the vent from the front unless you are running a trans brake. We installed our vent in the top of the tail shaft housing near where it meets the case and ran a rubber hose up to a vented puke tank. This way if it pushes fluid out the vent into the tank it can drain back down into the trans
I do have a brake, so your saying I should plug the front vent?
