ive used them both both worked well no problems !!! but the indy aluminum block is about 170 lbs lighter than my old mopar steel block the indy block seems to run a bit cooler on the street also
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
