I looked at the application instructions and am having trouble understanding the following:
"Avoid overlapping wet to dry as this can cause water spotting because the product will not be able to penetrate a dry area that was treated as well as in an area that has been treated but not yet dried."
What does this mean? How do you avoid a wet/dry interface as you move across the floor?
I read it as do not go back over an area that has already been sprayed and has since dried or spotting could occur.
I'd start on one end and finish on the other where you can exit. Don't end up back where you began.
It should be a nice garage when it's all done
