Originally Posted by lewtot184
tappets are bleeding down a little. it doesn't take much bleed down with a hydraulic tappet to get pretty noisey. i'd check the preload; you may need more.
iagree
It still seems noisy to me, even after the initial "loud" 5 seconds after starting. That may be normal with that particular cam?
