if that's a victor intake then it won't have any "tilt" towards the front at the carb pad. engines usually set a few degrees down in the back and most manifolds have a 3-4 degree tilt down towards the front of the carb pad. your engine/trans are probably ok. you may want to have a very careful look at the intake to see if there is a front and back but i don't think it has this. and, looking at a edelbrock catalog it looks like most of those race intakes don't have any angle cast into them.
