Measure from the center of the crank to the K-frame. 5 1/4 inches is what you want to see. Measure from the center of the crank to each frame rail. Subtract lower from the higher number and the difference should be 2 1/2 inches. The motor sits closer to the right frame rail by 1 1/4 inches. Measure and report back.
With the car still on jacks (I will downjack and take all measurements again) the distance from center of crank, as measured from center of crank bolt, to K frame is 5 1/2 inches. Distance to passenger frame rail 14 1/2 and to drivers frame rail 17 inches
