The set of b1 originals I have only go 375 at .650 and fall off from there.
If the heads aren’t “ported”........ the power numbers would make more sense.
And of course, then the question about how “correct” the manifold dimensions are comes into play.
Mine were ported and then filled about 1 inch up. They were flowed for a street engine. Looking at them they had ground them to whatever size they wanted then epoxied them, and flowed. I knocked all the epoxy out and scuffed up the ports before installing them. Mine is not a street engine. So I do not consider them to be ported or at best a hack job at porting.
As to the manifold. It only flows air as I am port injected. Fuel is injected 1 inch above the head port. Alcohol. Although I was listening to a few minutes of Daren Morgan's seminar and he commented that mech injection and port injection would benifit with a smaller port and valve in order to keep air velocity up. Goes against everything I thought but keeping velocity up makes sense..lol
